RCU Forums - View Single Post - Kyosho G Trick
Thread: Kyosho G Trick
Old 03-06-2003 | 12:31 AM
rjpilot
Default Kyosho G Trick
Anyone assembled a Kyosho G trick lately?
I was less than impressed with mine.
Have had many Kyosho planes previously, and all were great quality, but the G Trick which I just got has several areas where the wood and covering have been compressed, and the fiberglass cheek cowl was damaged in one area, and doesn't cover the cut away covering on the fuse sides in another area.
The fuse former for the wing dowels had to be redrilled about 1/4 inch lower, the belly pan had the fiberglass seperated in places, and the aluminum motor mounts were apparently drilled too large, and when tapped, the threads are not deep enough to hold the 3mm bolts, as any tighteneng strips the threads.
I redrilled, and used larger bolts.
Just wondering if anyone else has had these problems, as it seems unusual from what I have seen in the past from Kyosho.
Ron Jahnig
