RCU Forums - View Single Post - Kyosho G Trick
Thread: Kyosho G Trick
Old 04-06-2003 | 02:51 PM
swill
My Feedback: (17)
Default Kyosho G Trick
Sounds about right for a G-Trick. Mine was severely lacking glue in the fuselage (who knows about the wing). Check to see if the balsa sides are glued to the ply doublers, check to see if firewall and LG area have enough epoxy, as well as the wing hold down plate. Mine went together OK in terms of fit/finish... just the belly pan was hard to keep aligned while the epoxy cured. There are better values out there for the money... at least it flies well!
