RCU Forums - View Single Post - Trimming HELP!!!
Old 06-26-2007 | 08:27 PM
Aresti-RCU
Default Trimming HELP!!!
Still stucked with trimming my glow Genesis. The plane still needs significant backpressure to fly inverted, but KE performance is horrendous. It pulls to the wheels with both left to right and right to left KE flight. Right rudder application needs 9% up elevator mix. Left rudder is at 18% and counting since it still pitches to the wheels significantly. If I move the CG back a little more to relieve backpressure on the elevator stick, wouldn't KE deteriorate even more (i.e. needing more up mix?) I guess I will end up at 25% up mix with left rudder as of now (and still not satisfied with inverted flight)
Do you guys have any idea where else to look? TIA
