RCU Forums - View Single Post - CA on Vertical joints
Old 06-27-2007 | 12:38 AM
AviationNut
Default RE: CA on Vertical joints
For vertical joints, I put a drop at the top and let it run down the joint. This way there isn't as much excess at the bottom, if any. One of those thin extender tips helps to keep the amount applied under control. Also, I use wax paper over the plans - the CA doesn't seem to stick to it as much as it does to plastic. Hope this helps.
