RCU Forums - View Single Post - Aftermarket ECUS ???
Old 06-27-2007 | 05:39 AM
digitech
My Feedback: (10)
Default RE: Aftermarket ECUS ???
ORIGINAL: John Casey
Start and run times.?????..........
ECU data is hardly any indication of the condition of any jet engine good or bad.
It won't tell you that the engine was run through the trees,and crashed
in a COMP arf mig 15 in Delray beach florida, by a fellow englishmen, with witnesses,
and then ponded off to someone. in California... with grass stains
and bent compressor blades...... as newly factory rebuilt and never flown.
heck you can zero time
a jetcat ecu just by holding the menu button down for 1 minute till all the leds all flash together
(at least on the older models) wiping out the run times.
I will check into the Gasper Fadec.
The AMT 280 has magnet type rpm sensors as well.
thanks for th input guys...
you forgot 2 important items:
most manufacturers can tell you about the owner history
powerfull forum where almost everyone nows each other
