RE: SERVOS!!!!!!!!!!!!
Every servo has a wire lead that you plug into the receiver. Futaba servos have a "key" (essentially a tab of plastic) on one side of the connector that plugs into the receiver. This is done to ensure you plug the servo in correct (I assume). Not all receivers have the cutout to support this "key", in which case you need to cut that off. Hopefully this is clear, otherwise maybe someone with some pictures can better explain it.
