RE: SERVOS!!!!!!!!!!!!
Hey beginners.............
If you don't already know, the Futaba male connector won't plug into any female connector unless the female connector has been designed to accept the specially shaped Futaba male connector. UNLESS you take out a razor blade or knife and successfully cut off the tab that Futaba molds on their male connectors. Don't cut yo'sef. And don't slip and cut more off the connector than that tab.
Then you can use those Futaba servos with almost every other brand of stuff. Or you could buy almost any other brand of servo and use it with almost anything, including the Futaba stuff.
