RE: CA on Vertical joints
I am using the plastic drop cloth, the stuff I am using, Handibond, seems to stick doggedly to it. I am implementing the "use only enough glue to stick the pieces together until I can unpin them. I will probably have to spend all this evening getting the little chunks loose from last night....
Minn, when are the 85 deg. retracts going to be available? Thanks.
