Originally posted by bdtsr
Those engines you converted, are they the same as the current crop? If yes, then it's a dead issue. If they are not the same, then maybe a revisit is in order?
It was a long time ago, there were two versions, one with a roller bearing on the front and the other with a roller...I converted the ball bearing versions...Maybe they have changed.....Seems like they ran about like a G38, 7000 rpm with a 20-8....
