RE: Brazing SS header
Adam
I would not do it on the plane if I was you, try putting it all together and wick in a little CA to hold it all in place whilst you remove it carefully, then Mig weld it, you could do one joint at a time, spot the weld on then check the position hasn't moved, this is my thoughts after getting it wrong myself, good luck.
Mike can't braze for toffee.
