RCU Forums - View Single Post - cen nx 76 engine Issues!! what do i do now??
Old 06-29-2007 | 10:29 AM
steven16's Avatar
steven16
Default RE: cen nx 76 engine Issues!! what do i do now??
ya i know that but i havnt even done break in yet because it runs so bad . ill start the engine and it will sit and idle roughly but idle but then all of a sudden it sounds like it runs out of fuel revs up then dies but the tank is full no holes in the fuel lines the pipe is sealed with no leaks but it still does it or i can sit there and keeep pumping the primer while its running to keep it running with the high speed needle so far out it should flood like crazy?!! then i tryed reving it up a little bit and it would be ok untill a litle over half throttle then it would lean way out rev up then die but still the high speed needle is as far out as it can go??
