Seagull Xray
C G question... The manual says "7cm behind leading edge, measured at wingtip" where will the C G balence point be on the wing in relation to the fuse? ie: where do I put my fingers? I'm used to the balence point near the fuse and main spar. The Xray wing is tapered, Do I envision a line 7cm behind leading edge, from wing tip to wing tip, and place the balence point there near the fuse? Or place the fingertips out at the wingtips where the 7cm was measured?
The Xray is a center mount wing, do you balence it right side up or upside down?
I would like to get it right, I think I am close, the plane seems to fly OK but... is a bit of a chore at slow speed.
Thanks for any help!
