Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Seagull Xray >
Seagull Xray
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Seagull Xray
Old 06-29-2007 | 11:46 PM
CH-53's Avatar
Default Seagull Xray
C G question... The manual says "7cm behind leading edge, measured at wingtip" where will the C G balence point be on the wing in relation to the fuse? ie: where do I put my fingers? I'm used to the balence point near the fuse and main spar. The Xray wing is tapered, Do I envision a line 7cm behind leading edge, from wing tip to wing tip, and place the balence point there near the fuse? Or place the fingertips out at the wingtips where the 7cm was measured?
The Xray is a center mount wing, do you balence it right side up or upside down?
I would like to get it right, I think I am close, the plane seems to fly OK but... is a bit of a chore at slow speed.
Thanks for any help!
Old 06-30-2007 | 03:19 AM
Default RE: Seagull Xray
G'day Mate,
If you have flown the plane, & it sounds like you have, follow this trim chart, at least #4 Centre of gravity, & adjust as required.
http://www.palosrc.com/instructors/trim-chrt.htm
Old 06-30-2007 | 09:03 AM
rmh's Avatar
rmh
CH- you are making way too much work out of this .
hee is a very simple approach which puts you "close enough" as there is NO perfect CG --
I have th same model ,by the way with a 480 EFite motor and 1320TP batt and 11x5/5 prop (quick response setup)
Doi this
take full span - call it 40 " whatever - half that is 20 and half that is 10
measure in about 10"from each tip rib.
that point on each panel, wing is about the average width (chord) of the wing.
so treat is as the entire chord .
at that point measur back 30%
say the chord there is 9"--30% would be 2 and 3/4 inches.
-If you connect this point on each wing panel with a straight edge you will be able to magic marker a point on the fuselage.
with thumb n forfinger--pick up moder under this point
worrying aboutmaking cg adjustments upright or inverted is a waste of time - c/g is cg - do it easiest way for you.
now fly it - if you feel it is too stable - move the batt back some .
the trim charts will give you something to do - but basically with the model done straight and hinged decently - it flies extremely well -- forget thrust angles etc.. low speed is a chore for you simply because wing loading is way higher than foamies of the same size
lots of expo and practice in holding in proper power will get you going .
Old 02-07-2009 | 02:26 PM
My Feedback: (73)
I just completed this kit using E-flight 480 and a pretty standard 3s Lipo 2200mah, with it moved as far back on the battery tray as I can without covering the removal screw this bird is slightly nose heavy, but that's ok, better than tail heavy, if fly's awesome with unlimited vertical, it will do everything my extras and 540's will do.Great bird at a great price. I would post a pic if I could figure out how? You can view it in my models though.
