RCU Forums - View Single Post - E flite dimante 25 E
Old 06-30-2007 | 07:01 AM
  #40
hagraw
Default RE: E flite dimante 25 E
I have 4 flights on my Diamante. Power is e-flight 32 fueled by flightpower 3s1p 3700 turning a 13 x 8 prop, this combo draws 39 amps at full throttle on the ground, power is adequate for pattern flying,I do believe the 32 needs a 4s pack to realy hoof it. My original intention was to power it with an Axi 2820/12 on 3s, I need to make up some stand-offs to position the Axi further forward.
Only hiccup during assembly was the wheel / spat mounting. if you use the standard mounting set-up the wheels foul the spats, i.e. the spats sit too low over wheels and contact the outer diameter, one solution is to reduce the depth of the axle slots in the spats with a plywood or similar insert, a less than ideal solution would be to go for smaller wheels.
The Diamante flies well and is a more stable platform than the Brio. The wing flies snaps well, the spins I tried where somewhat tame, sort of midway between a spiral dive and a fully developed spin, I'm currently flying with the cg at the rearmost recomended position, some experimenation may aid the spin behavior. It flies pretty awsome sideslips, this comes in handy considering the Diamante's slipery airframe.
