RCU Forums - View Single Post - e- conversion
Old 06-30-2007 | 09:16 AM
pritam007
Default RE: e- conversion
for exhisting glider , motor on pod would be fine as we dont have grass field in INDIA, but here is clearence of only 8" dia. prom, wont mind to make another pod for same if required higher dia prop.
one more ?,,,
i have a Dynaflite "Butterfly" kit , .10, .15 engine powered glider( 98" wing span, with engine mode aprox weight might be around 1200 - 1500 grms, i d like to convert it BL, (with good climbing authority) and minimising the weight, only purpose of motor is to gain height and few power brusts to hunt for thermal.........
is it good to have small dia prop running at higehr RPM than big dia, prop at slight lower RPM for a glider ????
thank you and regards
pritam patel
