I'll give it a try as a trailing setup when I put the new forks in - I told you I had bent them (see 1st post after yesterday's trial above)!
Just to see if it rides any better. At least when they are as a trailing setup, the upper triangle thingy that holds the forks hits some stops on the chassis, limiting the amount of turning - which is good, at least the servo doesn't take it all by itself.
I know you kept yours standard, must be the better climate over there that keeps it running good
Next try, I'm going to the other side of the parking lot curb, it's wider. The one i rode yesterday was just 2 passage lanes, the other side has that and 2 rows for parking.
How about this?
http://www.mp3.piaggio.com/index_eng.html
See ya!
