ORIGINAL: Ralph White
I have looked thru the posts about Solartex, but cannot find an answer to this question. I plan to cover my Aeromaster with Solartex. I plan a white base color with red and blue trim strips and checker board on bottom of wing. Can I cut out the red or blue trim strips from solartex and apply it over the white solartex as can be done with monokote (Iorn the strips on)? I know I could paint the red or blue strips on but believe I would prefer to apply solartex trim instead. Can I use the windex method as with monokote?
Thank you, Ralph White
The only problem I see with ironing the strips on is going to be the end appearance and additional weight. Solartex, while noticeably lighter than Coverite, is still a fabric, and thus heavy. Also, since it is a fabric, the strips, especially if you do the checkerboard with strips and especially the overlaps, are going to quite noticeable.
Unfortunately, the Windex method only works with Monokote. The adhesive in Monokote is different than the other coverings.
To make cleaning easier, and minimize/prevent staining, Solartex really needs a clear coat. I would suggest painting the trim and checkerboard with latex paint, apply all your decals, etc, then clear coat the plane.
