RE: RS4 3 EVO rear diff problem
I had a problem with the front diff gears on my 3 Evo RTR sedan that was related to a missing ball bearing on the output shaft. You may want to check your diff to ensure there are two ball bearings otherwise the shaft will wobble and ruin the gears quickly like mine did.
