Daniel,
I agree 100% with the others, get the gyro and forget the shiny blings. The Pro flys fine with stock head and grips.
The thing that makes any heli fly better, is correct mechanical set up and your abilities, not the bling thing. Maintenance is important to, periodically, lubricate all the bearing and check gear mesh. I'm an over-oiler, I lube everything after 10 flights, 50 flights is more resonable.
Here's a link for a telebee/zoom gyro, I have one on my T-rex 450 and it works fine, and a little less expensive than the G90.
http://www.helidirect.com/product_in...roducts_id=494
Good Luck,
Dave / Choppersrule
