RE: Dragonus thread?
If you want to get good cyclic linkage alignment with the 65's here's what you do.Use the recommended 12mm servo arm output hole.Bend the servo mounting arms about 5-10 degrees to the rear and use 3mm spacers between the arm and servo lug.Remove 2-3mm of material from rear of elevator mounting slot so it slides back.Those little fixes will give you vertical alignment on your cyclic linkages.
