RE: Its Here!! Double Vision
Finally got around to finishing my DV, after mounting the rudder controll horn-then I noticed it will not clear the elevator!! What the heck is wrong with this, I can only get 20-30 degrees of elevator travel this way. Has anyone mounted the rudder servo on the bottom of the fuse & put the horns way down on the rudder bottom? Its the only way I can figure out to get the 3-D travel needed on elevator. I am using a very long Dubro screw horn & pull-pull, I did test fit the supplied horns & even though its shorter it still gets in the way.
