RCU Forums - View Single Post - Mixing Epoxy Tip
Old 07-05-2007 | 09:49 PM
Bad_Daddy's Avatar
Bad_Daddy
Default RE: Mixing Epoxy Tip
Just put the 2 parts in a ziplock baggie, zip it shut, squeeze stuff around until it's mixed. Then cut a small triangle off one corner and apply your mixed epoxy like toothpaste. When you're done, throw the baggie away. With a little caution, you won't even need to wash your hands when you're done. [8D]
