RCU Forums - View Single Post - HELP ON FLEX SHAFT
Old 07-05-2007 | 09:50 PM
spicedcrab
Default RE: HELP ON FLEX SHAFT
hi,
what i did on mine was to solder the end of the flex shaft that goes in the motor coupling, this gives a little better bite. on the prop shaft you have to grind a little flat spot were the set screw goes so it doesnt spin there either. any allen wrench should work once you do these mods.
john
