HELP ON FLEX SHAFT
IN
I NEED HELP!!!!! I HAVE A DRIFTERL FROM HYDRO MARINE, NEMESIS 540 XL MOTOR, FLEX DRIVE, WITH A RUDDER. NOW I GOT THIS THING READY TO GO IN THE WATER. I DROP IT IN, HIT THE GAS, AND NOW THE FLEX SHAFT IS SPINNING IN THE COUPLE. WHAT IS GOING ON? IS THERE AN EASY FIX? AND IS THERE A GOOD ALLEN WRENCH FOR THE PROP STOP ON THE SHAFT?
I AM GOING NUTS ON THIS THING.
MIKE
MIKE
TN
hi,
what i did on mine was to solder the end of the flex shaft that goes in the motor coupling, this gives a little better bite. on the prop shaft you have to grind a little flat spot were the set screw goes so it doesnt spin there either. any allen wrench should work once you do these mods.
john
john
IN
i have stripped out the allen 3 times now on the prop coupler. i soldered the end tonight. it better hold or there will be a drifterl with alot of work for sale
WI
are we talking about the prp collar or the coupler on the motor? the coupler on the motor works by tighning two nuts wich grips down on the cable. tighten those and your good to go
