RCU Forums - View Single Post - What is it with some of these ARF's?
Old 07-06-2007 | 10:47 AM
opjose's Avatar
opjose
Default RE: What is it with some of these ARF's?
And to repeat his excellent post:
ORIGINAL: RCKen
When you get an ARF in before you put heat to the covering you need to go over ALL of the edges and seams with a covering iron to ensure that they are completely sealed before you try to shrink the covering. If you don't do this the covering will pull away from these areas as the covering starts to shrink.
This is a MUST before you use the heat gun.
