RCU Forums - View Single Post - Good First Time Buggie?
Old 07-06-2007 | 11:13 AM
Bloodlezz
Default Good First Time Buggie?
Hey, Im going to buy a 1/8th scale buggy at Xmas and i was wondering if this is good for a first time one ? Here is the stats etc.
Tuned Aluminimum Exhaust Pipe
GO 21 Engine Rear Exhaust Pipe
Sway Bar Fitted As Standard
Front CVD shafts
Carbon Fibre upper plates and radio tray
Highly adjustable throughout for race setup
Bottle Of Fuel ( 25 - 30% )
Glow Start And Charger
Failsafe
£277 ( $544 )
Forgot to add :
SPECIFICATIONS:
Width: 315MM
Weight: 3580g
Length: 520MM
Wheelbase: 325~330MM
Gear ratio: 11.69 : 1
Engine: New Powerful GO 21
Wheel Track: 306F/308R MM
FEATURES:
1/8 Scale
Front Pivot Ball Suspension
Captured Arm Mounts
Front Universal Drive Shafts
Sealed Bevel Gear Diffs
Big Bore Racing Shocks
Complete Ball Bearings
Powerful .21 Pull Start Engine
44 Tooth Steel Spur Gear
Low CG Radio Tray
Fully Adjustable Suspension
3 Shoe Aluminium Clutch
150cc Fuel Tank w/ Filter
High Torque Steering Servo
Spiral Cut Steel Conical Gears
Heavy Duty Suspension Arms
27MHZ CE approved Radio system with changeable crystals.
