RE: Rustler pulls right, help!
First, don't multi-post...
Secondly, check if your servo saver is loose. Make sure you adjust the sub-trim on your transmitter.
You can't center it while its on its wheels. The most accurate way to center it is by adjusting the steering sub-trim WHILE the truck is in motion. Not slow, but at a decent pace where you can notice how far it dodges to the right.
