Starting matrix
I'm having a hard time starting my matrix with the standard flywheel on a starter box. I've tried a larger flywheel but the brakes are in the way and i can't bolt my engine. what you guys are doing ? What flywheel are you using with a starter box ? Did you grind the chassis to make the opening larger ?
I'm waiting for your help.
