CEN Racing This forum is to discuss all CEN Racing products.
Starting matrix
Old 07-06-2007 | 06:59 PM
Default Starting matrix
I'm having a hard time starting my matrix with the standard flywheel on a starter box. I've tried a larger flywheel but the brakes are in the way and i can't bolt my engine. what you guys are doing ? What flywheel are you using with a starter box ? Did you grind the chassis to make the opening larger ?
I'm waiting for your help.
Old 07-06-2007 | 08:28 PM
Default RE: Starting matrix
Im doing stock everything with an ofna starter box. http://www2.towerhobbies.com/cgi-bin...&I=LXHUC7&P=ML
Old 07-07-2007 | 01:37 PM
I manage to start it correctly. I think it is because my engine still got too much compression for the starter box. I must pre-heat the engine before i can it started.
Old 07-08-2007 | 10:27 AM
Im using a Mugen flywheel and OFNA chrome top starter box.
