RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 07-07-2007 | 06:18 AM
  #1891
CrashPro's Avatar
CrashPro
Default RE: Nitro models pusher Bobcat?
ORIGINAL: mr.scale
do you really need the rudder? can i just installed them in a fix position or i have to go with the dual rudder servo installation?
fernando
My friend Serge and I both bought our Bobcats at the same time, I installed rudder servos, he did not.
The only time I used rudders were on landing,...to help line up the runway. Winds are usually straight down the runway at our field, so I found I didn't really need the rudders, so I removed the servos, and fixed the rudders. I also have the elevator servo inside the stab now, so plane is alot cleaner (and faster) without all those servos hanging out there. I would say, if your field is not prone to strong cross winds,..then don't bother with putting rudder servos on.
