ORIGINAL: sparky925
OK all, i am doing a little research for myself for my next 2 meter ship to be electric.
Please post your setups: motor, polys, speed controllers
Also add your preferred and tested props with rpm and current.
Thanks in advance.
Might as well kick this thread and see if it breathes. I am building a C-ARF Impact and plan on putting the following components in it after seeing just how great they perform in my new Hanger 9 Sundowner F1;
Axi 5330/F3A
2 x EVO 5000 6S2P is series (12S)
Jeti Spin 99
Mejzlik 20 x 12E Composite
The following WhattMeter and RPM numbers are from bench tests on my Sundowner with the same setup;
3,650 Watts
81.5 Amps
7,110 RPM
Firing this thing up was almost frightening, it felt like it was going to tear the engine and Budd Engineering softmount right off the firewall!
Jack
