RCU Forums - View Single Post - CMP P-26
Thread: CMP P-26
Old 07-08-2007 | 09:08 PM
pdansalvish
My Feedback: (23)
Default RE: CMP P-26
Antique_opa,
The wing is made of foam and covered with 1/16 balsa. So moving the landing blocks would be difficult. To make them stronger, I'm going to soak them with foam safe CA. Also, I found out the covering is a low-temp. The pictures attached are of the aileron covers with their servos attached and the other two is the right wing with the hole drilled in the top for the servo wire and the servo mounted in the wing. One concern I have is the aileron cover is screwed into the 1/16 balsa sheet. I think I will fill the hole with foam CA for a little extra bit.
Dave
ID:	718624   Click image for larger version
ID:	718625   Click image for larger version
