I would say go for a 2,000 mAh pack as that will allow you to use it in other planes later on and it may help with the CG. Despite using the stock motor my 182 needed a larger pack to obtain the correct CG. Got a pic of your motor? Becareful as you need to know what prop to match the motor with.
