RCU Forums - View Single Post - Weight Requirements
Old 07-08-2007 | 10:04 PM
  #38
DaveL322's Avatar
DaveL322
Default RE: Weight Requirements
Hacker A60-20S
TP Extreme 5000s
Castle 85HV, low timing
APC 18x12PN (repitched by me)
7800 RPM @ ~90F, 75' MSL
Neu 1515-1.5Y 6.7:1 BAM PG
TP Extreme 5000s
Castle 85HV, high timing
APC 18x12.75PN (repitched by me)
8000 RPM @ ~90F, 75' MSL
Lighter always flies better. Wingloading can be too light (use a smaller wing!). Electrics have there advantages as do glow......if glow is perceived to have an advantage in 5% of the windiest conditions.....there is the other 95% of the time when electric has the advantage? Yes, the rules would not seem to be fair in that glow can exceed 5KG at takeoff and electric can not. But I would never support a weight increase for electrics as they are clearly competitive now, and will be increasingly so as they continue to develop at a very rapid pace - giving electric a rules advantage would pretty much obselete current day glow setups. I would absolutely support a rule change stating 5KG takeoff weight for all aircraft (heck my glow stuff was 4.75KG at takeoff).....and that would have also have the effect of obsoleting most glow stuff.
Regards,
Dave Lockhart
