RCU Forums - View Single Post - Single Servo Aileron Setup???
Old 07-08-2007 | 10:13 PM
DavidAgar's Avatar
DavidAgar
My Feedback: (108)
Default RE: Single Servo Aileron Setup???
If you are using a single servo, using the ailerons as flaps, I do not believe that this is possible. You would need 2 servos. You can use 1 servo for each aileron or mount 2 servos in the wing center and have the second servo hooked to a flaperon bracket on the aileron servo. Good Luck, Dave
