RCU Forums - View Single Post - Main Hatch fitting
Old 07-09-2007 | 05:06 AM
i3dm
My Feedback: (51)
Default RE: Main Hatch fitting
You could always fabricate a "L" shaped piece of plywood (or composite material) and have it slide into place (its glued to the hatch) into a slot in the fuse, one on each side, that sucker will keep the mid section down, but this only works if you have room to slide the hatch back when wanting to remove it, and im not sure if thats your case ?
