RE: 2 meter electric setups
OK Guys, if you use the A123 cells for a 2 meter aircraft what configuration do you need? It seems as though the voltage and some other parameters are different. Can you guys explain the differences pro and con using a big picture scenario, for example bang for the buck, weight, charge method, electrical charge/discharge benefits,etc?
Trying to get a handle on this electric power application thing.....
Gene
