ORIGINAL: sparky925
well that sundowner setup sounds good, but your running 12S?
I thought you couldnt run more that 10S in AMA Pattern?
There is no rule that says you can't run more than 10s in AMA pattern... there will be a rule in FAI for 2009/2010 that limits voltage.
