RE: TS2 POST IT HERE...
i'll set it up with an empty tank, once i've run the engine in i'll see how it performs, if it's too nose up i'll add some more weight.
another question, i was looking at the OS engine last night getting it ready to mount on the boat. there's 2 nipples on the exhaust pipe (one for the pressure line to the tank, and another one), and another nipple on the shaft casing. in the diagram in the manual, there's a tube going from the exhaust to the side of the shaft casing. the nipple on the shaft casing looks to have been plugged with some plastic. I couldn't find anything in the instruction manual about pressurizing the shaft case. i assume i need to put the tube on, so i have, but if the nipple is blocked, should i unblockit? or is that a one way valve?
sorry for all the questions, i've never run an outboard before, i know plenty about standard marine & buggy engines though.
Cheers
Jason
