RCU Forums - View Single Post - Midwest Sweet Stick Revival (a work in progress)
Old 07-12-2007 | 12:19 AM
sscherin's Avatar
sscherin
Default RE: Midwest Sweet Stick Revival (a work in progress)
More progress and new pictures..
Today I hinged the rudder..
First thing I did was mark the hinge points from the plans onto a 1/4x1/4 hardwood stick cut to the length of the rudder hinge line
Then I drilled 1/8" holes in the stick on the drill press.
Now I have a drilling jig for the robart hinges.
I also added a little 1/16 sheet scrap to allow a small gap between the stab and rudder. The covering will close this up a little.
The jig gets taped to the rudder (pic 1)
then drill the holes (pics 2)
In pic 3 you can see we have a nice set of perfectly aligned holes.
In Pic 4 we follow the same process on the stab. (note the 1/16" spacer)
Pic 5 I've sanded notches into the rudder for the hinges.. you want them flush with the TE when folded over 90 degrees.
Pic 6 shows the Rudder installed but we still need to cut the bevels.
Pic 7 shows the finished rudder.. it has almost 45 degrees movement and a nice tight hinge line.
ID:	721218   Click image for larger version
ID:	721219   Click image for larger version
ID:	721220   Click image for larger version
ID:	721221   Click image for larger version
ID:	721222   Click image for larger version
ID:	721223   Click image for larger version
