RE: Please help me with break-in! Idle through 3 tanks?
Ok, the break-in is done, I drove around real rich for five tanks at around 230 degrees, I had to wrap the cooling head and crankcase in many layers of aluminum foil but I did it! It was 95 degrees outside today so I was suprised it wouldn't get up to temp.
Anyway, I tried to change the needle setting to the "after break in settings" mentioned in the manual but then the engine wouldn't start no matter how much I pulled, feathered the throttle, loosened the glow plug, changed the glow plug, but no luck, please! somebody help!
