RCU Forums - View Single Post - Battery for Blade CPP
Old 07-13-2007 | 11:34 AM
Default Battery for Blade CPP
I just finished overhauling my CPP. Changed to SuperSkids, titanium boom, Micro alum twin tail mount and dual motors with heat sink on each. First thing I noticed is that the G90 holds much better at a lower gain setting- about 50% at the Tx. Second the hover time is reduced about 30% with training gear and above setup. Total weight with TG is 390 gms. That is 90 gms heavier than the spec wt (no TG) of 298 gms.
I had to move the std 800 mAh battery as far foward into the canopy as possible and it is still slightly tail heavy. My next step is to go to a higher capacity battery 1100 - 1300. I will appreciate anyones help or comments on the above. I am new to using LiPo and expect that I will need a new charger/balancer for the larger battery - correct ?
