RCU Forums - View Single Post - setting idle on electric model
Old 07-14-2007 | 04:02 PM
  #37
OhD
Default RE: setting idle on electric model
ORIGINAL: Scott Smith
ORIGINAL: OhD
I was just thinking of starting a new thread on the Spin to see if anone is happy with them.
140 flights and no issues with my Spin 99. Setting are:
Manual brake 12% initial, 68% final (prop just stops as plane is touching down.)
21 degrees timing (was running 25, plenty of power with 21 and a few less amps.)
1.0 sec acceleration
Slowdown cutoff
Initial point auto - on
End point 2.0 (output pulse measured at 1.93...Jeti says to be less than measured for high stick but full throttle was reached too early)
Auto inc end - off
Expo throttle curve (12Z transmitter, 3 point spline, point 2 at -17, +22 rate)
I fly with an idle up set for about 400 rpm (once motor is running...just flipping on idle up will not start the motor.) I went the idle up route because a few times early on, after an extended down line, it would make an awful noise on throttle up if I got into the throttle too quick.
Scott
Thanks for the feedback Scott. I will try the 21 degree timing and a longer acceleraion settings. The noise I heard was probably the same as yours as I was at the bottom of a fig. M getting back on throttle. I thought something broke.
Jim O
