ORIGINAL: clpete90 A.T. Do you know of any hitec ESC that will plug into the Perfex Receiver with out any modifications. Please send the stock number if you know of any.
Thanks Chris
All those listed
Hitec ESC have S-01 plugs which fit Perfex RX without any modification. Leads are Yellow signal, Red (+) black (-) so simply plug in so the black line up, red leads line up and the white & yellow line up and follow the very simple set up directions, As with any ESC, better to have a higher rating than you expect to use - check the power your motor will draw and go for the ESC which has a higher rating.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
