I’ve just purchased a Great Planes Dazzler 40 ARF, however, I have a couple of questions I would like answered.
1: When joining the wing halves together, would anyone recommend using Epoxy\Fibreglass Tape in the middle of the wing to add extra strength? Or just use the wing tape provided with the kit will be sufficient?
2: When gluing the wing to the fuselage do you also cut away the covering where the 6 triangle wood blocks come into contact with the wing? (There is no mention in the instructions to do this except for cutting the film where it comes into contact with the wing saddle on the fuselage).
Your thoughts are much appreciated.
Regards
Tasman !!!
