RE: Nitro models pusher Bobcat?
Quick questions: How did you guys run the elevator servo wire? I don't see a straight path to the rudder from the inside, unless I'm not seeing something...do I need to do surgery to route the wires without seeing them?
I made a nice box for the HS125 to fit in the stabilizer, and I used a bigger full-size servo for the rudder, and I want to couple it to the other one as I saw in previous posts. Can anyone tell me the best way to do this? ie. what did you use for the rod, and what connectors did you use?
I finally turned on the new Spektrum 7 - very nice so far.
Mark
