RE: Midwest Sweet Stick Revival (a work in progress)
Main landing gear done.
Tail wheel 90% done.. I need some wheel collars to finish up.
Engine test mounted. I turned it 90 deg from vertical this time.. I was somewhat surprised how tight the clearance between the fuselage and muffler is. It'll clear with no mods though.
Mounted the servos and control horns on the wing.
Made the aileron push rods but still need to solder the clevises on.
Added hardwood servo rails in the fuselage.
Started installing the push rod tubes for the rudder and elevator.
I need a more threaded rods to finish up plus add the control horns.
still to go on the radio install is mounting the power switch, throttle push rod and routing the antenna
fuel tank might be a bright idea at some point too.
