RE: GST Transmitter Problem
Replacing the lever isn't too hard, just a little time consuming. The radio they gave you may not have been set up. you want to adjust the radio and shift linkage so that it doesn't over travel. It prob did and the 144 oz servo snapped the shift lever, which could and should be stronger. I changed to an M8 radio and went brain dead and did the same thing, so your not alone out there.
