RCU Forums - View Single Post - To use the trim or not?????????HELP!
Old 07-16-2007 | 06:12 PM
darticus
Default To use the trim or not?????????HELP!
When hovering the CP Pro is it correct to Trim when the heli goes slightl slowly left or right due to gyro settings or should the left lever on the radio be used to correct the slight movement? I don't need bad habits but I have been using the trim on the radio and not the lever. Thanks in advance!
