ORIGINAL: rastus21
Gday Marktur, you and me are on the same wavelength here, I also are building a retract version of the het f20, using Carls info, and yesterday received my bobcat....yeah! This bobcat is a hot looking machine for sure, may fly it this weekend, hopefully..... I'll use it for practise for the f20, cuz I've put a lot of work into the f20 so far.
Cant beleive how good the quality of the bobcat is, it looks like a much more expensive plane for sure, only paid $190.00 AU for it. Quite large to.
Anybody tell me a good prop for the 76???
Matt
Hi rastus,
I used an APC 11x7 and it seemed to fly it well. I will be getting a Graupner 11x8 when I get a chance. As I said earlier, I would add some glue to all of the formers and landing gear blocks that I could reach. when I endoed from about 20' up the whole servo mount came loose and broke both formers that were attached to it. I do not believe that would have happened if I had added some epoxy.
Blessings, Terry
